Ir para o conteúdo principal
Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink Replacement
O que você precisa
  1. Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink  Replacement, Back Cover: passo 1, imagem 1 %32
    • Turn the laptop on to its back.
  2. Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink  Replacement: passo 2, imagem 1 %32
    • Use the Phillips #1 screwdriver to remove five 1.2 mm screws from the back cover of the laptop.
  3. Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink  Replacement: passo 3, imagem 1 %32
    • Remove the back cover using the opening tool, leaving the laptop back exposed.
    • Use the opening tool to pry the edge and work your way around the perimeter.
    • Careful to undo the clips before removing the back cover.
  4. Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink  Replacement, Fan and Heat Sink: passo 4, imagem 1 %32 Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink  Replacement, Fan and Heat Sink: passo 4, imagem 2 %32 Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink  Replacement, Fan and Heat Sink: passo 4, imagem 3 %32
    • Use the Phillips #1 screwdriver to remove all five 1 mm screws holding the fan and heat sink down.
  5. Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink  Replacement: passo 5, imagem 1 %32 Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink  Replacement: passo 5, imagem 2 %32
    • Pick up the fan and heat sink and carefully and remove it.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Gateway, Team 1-3, Saknee Fall 2021 Membro de Gateway, Team 1-3, Saknee Fall 2021
GCC-SAKNEE-F21S1G3
4 Membros
9 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 69
Duração total: 904
