Ir para o conteúdo principal
Lenovo ThinkPad X1 Carbon 5th Gen Back Cover Removal
O que você precisa
  1. Lenovo ThinkPad X1 Carbon 5th Gen Back Cover Removal, Back Cover: passo 1, imagem 1 %32
    • Turn the laptop on to its back.
  2. Lenovo ThinkPad X1 Carbon 5th Gen Back Cover Removal: passo 2, imagem 1 %32
    • Use the Phillips #1 screwdriver to remove five 1.2 mm screws from the back cover of the laptop.
  3. Lenovo ThinkPad X1 Carbon 5th Gen Back Cover Removal: passo 3, imagem 1 %32
    • Remove the back cover using the opening tool, leaving the laptop back exposed.
    • Use the opening tool to pry the edge and work your way around the perimeter.
    • Careful to undo the clips before removing the back cover.
Conclusão
If you follow these steps the back of the laptop will be exposed so you can work on other components of the laptop.
To put it back together follow these steps in reverse
Equipe
Gateway, Team 1-3, Saknee Fall 2021 Membro de Gateway, Team 1-3, Saknee Fall 2021
GCC-SAKNEE-F21S1G3
4 Membros
9 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 51
Duração total: 566
