Ir para o conteúdo principal
Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement
O que você precisa
  1. Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement, Optical Disk Drive (ODD): passo 1, imagem 1 %32 Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement, Optical Disk Drive (ODD): passo 1, imagem 2 %32
    • Turn your laptop over so the backplate is facing you.
    • Start with your Phillips #0 screwdriver and unscrew the 2 screws in each of the top corners of the backplate.
    • These screws should stay put on the backplate, and should not fall off.
  2. Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: passo 2, imagem 2 %32
    • With your Phillips #00 screwdriver, simply remove the one 3mm screw on the upper left side.
  3. Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: passo 3, imagem 1 %32 Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: passo 3, imagem 2 %32 Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: passo 3, imagem 3 %32
    • Remove the ODD by using a plastic opening tool to push the drive out of the side of the laptop.
    • Make sure to place the tool where we removed the screw holding the drive in place in Step 2.
  4. Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: passo 4, imagem 1 %32
    • Once the ODD has popped out, simply grab and pull out the drive bay.
Conclusão
Isaac
Membro desde: 10/30/23
109 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 4-1, Shaddix Spring 2024 Membro de UMass Dartmouth, Team 4-1, Shaddix Spring 2024
UMASSD-SHADDIX-S24S4G1
Membros da 4
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Duração total: 70
