Ir para o conteúdo principal
Lenovo ThinkPad W540 Hard Drive Replacement
O que você precisa
  1. Lenovo ThinkPad W540 Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32 Lenovo ThinkPad W540 Hard Drive Replacement, Hard Drive: passo 1, imagem 2 %32
    • Flip the laptop to the bottom so the backplate is shown.
    • Use a Phillips #0 screwdriver to unscrew the 2 captive screws that secure the backplate.
    • These screws should hold on to the backplate even after removal. So, you shouldn't worry about losing them.
  2. Lenovo ThinkPad W540 Hard Drive Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad W540 Hard Drive Replacement: passo 2, imagem 2 %32
    • Use a Phillips #00 screwdriver to unscrew the single 3 mm screw that secures the hard drive.
  3. Lenovo ThinkPad W540 Hard Drive Replacement: passo 3, imagem 1 %32
    • Lift up the bottom half of the hard drive at a 25 degree angle.
    • Simply pull out the hard drive.
  4. Lenovo ThinkPad W540 Hard Drive Replacement: passo 4, imagem 1 %32 Lenovo ThinkPad W540 Hard Drive Replacement: passo 4, imagem 2 %32 Lenovo ThinkPad W540 Hard Drive Replacement: passo 4, imagem 3 %32
    • Safely remove the plastic guard surrounding both the hard drive and ESD shielding.
  5. Lenovo ThinkPad W540 Hard Drive Replacement: passo 5, imagem 1 %32 Lenovo ThinkPad W540 Hard Drive Replacement: passo 5, imagem 2 %32
    • Carefully removing the ESD shielding surrounding the hard drive.
    • Do not disregard the ESD shielding unless your new hard drive or SSD comes with its own shielding. Failure to do so will lead to severe damage to your device.
Conclusão
Uma outra pessoa concluiu este guia.
Kevin Dang
Membro desde: 10/30/23
333 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 3-2, Konn Fall 2023 Membro de UMass Dartmouth, Team 3-2, Konn Fall 2023
UMASSD-KONN-F23S3G2
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 17
Últimos 30 dias: 36
Duração total: 143
