Ir para o conteúdo principal
Lenovo ThinkPad T580 Trackpad Replacement
O que você precisa
  1. Lenovo ThinkPad T580 Trackpad Replacement, External Battery: passo 1, imagem 1 %32 Lenovo ThinkPad T580 Trackpad Replacement, External Battery: passo 1, imagem 2 %32 Lenovo ThinkPad T580 Trackpad Replacement, External Battery: passo 1, imagem 3 %32
    • Slide the switch on the left side of the battery to the left.
  2. Lenovo ThinkPad T580 Trackpad Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad T580 Trackpad Replacement: passo 2, imagem 2 %32 Lenovo ThinkPad T580 Trackpad Replacement: passo 2, imagem 3 %32
    • Slide the switch on the right side of the battery to the right while applying upward pressure on the battery.
  3. Lenovo ThinkPad T580 Trackpad Replacement: passo 3, imagem 1 %32 Lenovo ThinkPad T580 Trackpad Replacement: passo 3, imagem 2 %32 Lenovo ThinkPad T580 Trackpad Replacement: passo 3, imagem 3 %32
    • Pull the battery directly out of the socket
  4. Lenovo ThinkPad T580 Trackpad Replacement, Bottom Case: passo 4, imagem 1 %32 Lenovo ThinkPad T580 Trackpad Replacement, Bottom Case: passo 4, imagem 2 %32
    • Using a Phillips #00 screwdriver, unscrew the eight 3.3 mm captive screws on the bottom of the laptop.
    • The "captive" screws will not come out of the case.
  5. Lenovo ThinkPad T580 Trackpad Replacement: passo 5, imagem 1 %32 Lenovo ThinkPad T580 Trackpad Replacement: passo 5, imagem 2 %32 Lenovo ThinkPad T580 Trackpad Replacement: passo 5, imagem 3 %32
    • Run a Jimmy along the crease of the computer all the way around, twisting it periodically to disengage the clips.
  6. Lenovo ThinkPad T580 Trackpad Replacement: passo 6, imagem 1 %32 Lenovo ThinkPad T580 Trackpad Replacement: passo 6, imagem 2 %32 Lenovo ThinkPad T580 Trackpad Replacement: passo 6, imagem 3 %32
    • Once all the clips are released, remove the bottom cover.
    • You may need to jiggle the case slightly to release the clips around the external battery bay.
  7. Lenovo ThinkPad T580 Trackpad Replacement, Internal Battery: passo 7, imagem 1 %32
    • Using a Phillips #00 screwdriver, remove five 3.7 mm screws holding down the battery.
  8. Lenovo ThinkPad T580 Trackpad Replacement: passo 8, imagem 1 %32 Lenovo ThinkPad T580 Trackpad Replacement: passo 8, imagem 2 %32 Lenovo ThinkPad T580 Trackpad Replacement: passo 8, imagem 3 %32
    • Unplug and remove the battery connector from the motherboard.
    • Remove the internal battery.
  9. Lenovo ThinkPad T580 Trackpad Replacement, Trackpad: passo 9, imagem 1 %32 Lenovo ThinkPad T580 Trackpad Replacement, Trackpad: passo 9, imagem 2 %32
    • Using a halberd spudger, unplug the trackpad cable from the motherboard.
  10. Lenovo ThinkPad T580 Trackpad Replacement: passo 10, imagem 1 %32 Lenovo ThinkPad T580 Trackpad Replacement: passo 10, imagem 2 %32
    • Using a Phillips #00 screwdriver, remove four 2.2 mm screws holding the trackpad.
    • Pull the trackpad out.
Conclusão
Ben Elkayam
Membro desde: 01/23/20
942 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team S18-G6, White Winter 2020 Membro de Cal Poly, Team S18-G6, White Winter 2020
CPSU-WHITE-W20S18G6
Membros da 4
Autoria de 24 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 15
Últimos 30 dias: 92
Duração total: 3,534
