Ir para o conteúdo principal
Lenovo ThinkPad T580 Keyboard Replacement
O que você precisa
  1. Lenovo ThinkPad T580 Keyboard Replacement, Unfasten the keyboard: passo 1, imagem 1 %32
    • Use a Phillips #00 screwdriver to unscrew the three 3.3 mm captive screws securing the keyboard.
  2. Lenovo ThinkPad T580 Keyboard Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad T580 Keyboard Replacement: passo 2, imagem 2 %32 Lenovo ThinkPad T580 Keyboard Replacement: passo 2, imagem 3 %32
    • Use a Jimmy to pry under the top left corner of the keyboard.
    • You may head a "click" or "pop" as the clips of the keyboard disengage.
  3. Lenovo ThinkPad T580 Keyboard Replacement: passo 3, imagem 1 %32 Lenovo ThinkPad T580 Keyboard Replacement: passo 3, imagem 2 %32 Lenovo ThinkPad T580 Keyboard Replacement: passo 3, imagem 3 %32
    • Continue prying along the top edge of the keyboard, releasing the clips as you go.
    • Once the top edge has been fully released, grab the top edge and hinge the keyboard upwards on the bottom edge.
  4. Lenovo ThinkPad T580 Keyboard Replacement: passo 4, imagem 1 %32 Lenovo ThinkPad T580 Keyboard Replacement: passo 4, imagem 2 %32 Lenovo ThinkPad T580 Keyboard Replacement: passo 4, imagem 3 %32
    • Pull the keyboard away from you, releasing the tabs along the bottom edge.
    • Be sure not to pull on the keyboard too excessively, as it is still connected to the motherboard via two ribbon cables.
    • Flip the keyboard over to rest face down over the trackpad.
  5. Lenovo ThinkPad T580 Keyboard Replacement: passo 5, imagem 1 %32 Lenovo ThinkPad T580 Keyboard Replacement: passo 5, imagem 2 %32 Lenovo ThinkPad T580 Keyboard Replacement: passo 5, imagem 3 %32
    • Use a spudger to lift up the two black, hinged locking flaps on the ZIF connectors on the motherboard.
  6. Lenovo ThinkPad T580 Keyboard Replacement: passo 6, imagem 1 %32 Lenovo ThinkPad T580 Keyboard Replacement: passo 6, imagem 2 %32 Lenovo ThinkPad T580 Keyboard Replacement: passo 6, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use a pair of blunt nose tweezers to pull the two keyboard ribbon cables out from the ZIF connectors.
  7. Lenovo ThinkPad T580 Keyboard Replacement: passo 7, imagem 1 %32
    • Remove the keyboard.
Conclusão
Austin Blakely
Membro desde: 03/11/19
19.640 Reputação
Autoria de 53 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 136
Autoria de 17.336 guias
5 comentários
Aren't there screws on the bottom of the laptop that ought to be unscrewed as well? That's what the T580 service guide says, I think.
Daniel Glus - Responder
This guide is wrong. You need to remove three screws on the bottom. Then slide the keyboard forward (towards the screen) and lift it up at the front to remove it.
Mart Conflin -
This guide is indeed incorrect. After just pulling the screws out of the back of the keyboard thinking they were "clips" as stated in the article, I can confirm that you DO need to unscrew the three center screws on the back of the laptop prior to removing the keyboard.
Dave - Responder
Hi Dave.
You and the other commenters are 100% right! I have updated the guide accordingly.
Alex Diaz-Kokaisl -
Is it possible to replace the non-backlit keyboard into backlit one?
Ahmad Naufal Firdaus - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 43
Últimos 30 dias: 175
Duração total: 3,769
