Ir para o conteúdo principal
Lenovo ThinkPad T570 Thermal Paste Replacement
O que você precisa
  1. Lenovo ThinkPad T570 Thermal Paste Replacement, Opening the back panel.: passo 1, imagem 1 %32 Lenovo ThinkPad T570 Thermal Paste Replacement, Opening the back panel.: passo 1, imagem 2 %32 Lenovo ThinkPad T570 Thermal Paste Replacement, Opening the back panel.: passo 1, imagem 3 %32
    • Unscrew all screws holding the back panel in place.
    • Remove the first battery by sliding the notches and pulling the battery outwards.
    • Use a plastic prying tool to release all the clips holding the panel in place.
  2. Lenovo ThinkPad T570 Thermal Paste Replacement, The insides.: passo 2, imagem 1 %32
    • It is recommended to disconnect the second battery too (marked in blue).
    • Unscrew the 4 screws holding the CPU heatsink and disconnect the fan.
  3. Lenovo ThinkPad T570 Thermal Paste Replacement, Removing the old thermal paste.: passo 3, imagem 1 %32 Lenovo ThinkPad T570 Thermal Paste Replacement, Removing the old thermal paste.: passo 3, imagem 2 %32
    • Clean the old thermal paste both from the cooler and the CPU. It is best to use isopropyl alcohol and cotton swabs or paper towel, but be careful not to go too hard on the CPU.
  4. Lenovo ThinkPad T570 Thermal Paste Replacement, Applying new thermal paste.: passo 4, imagem 1 %32 Lenovo ThinkPad T570 Thermal Paste Replacement, Applying new thermal paste.: passo 4, imagem 2 %32
    • Dont use too much thermal paste, just enough to cover some portion of the pad. If you have a spreader, use it. The thermal paste will apply evenly after you tighten the heatsink.
    • Last, put the heatsink back carefully and tighten the screws in order 1 -> 4 to ensure even pressure. Dont forget to plug in the fan cable.
  5. Lenovo ThinkPad T570 Thermal Paste Replacement, Other upgrades.: passo 5, imagem 1 %32
    • Once you opened the back cover, it is a good idea to upgrade the RAM or the SSD if you want.
    • It is also recommended to use compressed air to remove any dust in the laptop and the fan.
    • Dont forget to plug in the second battery before closing the back panel!
Conclusão
Uma outra pessoa concluiu este guia.
Simeon Brankov
Membro desde: 11/08/20
6.045 Reputação
Autoria de 49 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 32
Duração total: 1,492
