Introdução
If the internal battery for your Lenovo Thinkpad T560 has gone bad and needs to be replaced, follow this guide. Note that the Lenovo Thinkpad T560 has two batteries: an internal battery and an external battery.
The most common reasons to why this component needs to be replaced are:
- The battery is failing to charge effectively
- The internal/external battery has gone bad
Before replacing the battery, make sure to power down the device and disconnect it from any external power sources.
O que você precisa
Using the Phillips #0 screwdriver, remove the eight 7 mm screws holding the back panel to the T560.
Disconnect the battery connector from the motherboard by pulling it out of the port.
