Ir para o conteúdo principal
Lenovo ThinkPad T560 Battery Replacement
O que você precisa
  1. Lenovo ThinkPad T560 Battery Replacement, Back Panel: passo 1, imagem 1 %32
    • Before you begin this guide, make sure to disable the internal battery, power down the device and disconnect from any external power sources.
    • The external battery should be removed prior to back panel disassembly however this device doesn't have one so we aren't able to show the process.
    • Using the Phillips #0 screwdriver, remove the eight 7 mm screws holding the back panel to the T560.
  2. Lenovo ThinkPad T560 Battery Replacement: passo 2, imagem 1 %32
    • Use the iFixit opening tool to pry the back panel off your T560.
    • Work your way around the perimeter of the device to undo the clips and detach the back panel.
  3. Lenovo ThinkPad T560 Battery Replacement, Battery: passo 3, imagem 1 %32 Lenovo ThinkPad T560 Battery Replacement, Battery: passo 3, imagem 2 %32
    • Disconnect the battery connector from the motherboard by pulling it out of the port.
  4. Lenovo ThinkPad T560 Battery Replacement: passo 4, imagem 1 %32
    • Using the Phillips #0 screwdriver, remove the five 3.5 mm screws securing the battery.
    • Remove the battery.
Conclusão
Jackson Reynolds
Membro desde: 02/27/22
517 Reputação
Autoria de 5 guias
Equipe
Clemson, Team 1-3, Hunter Spring 2022 Membro de Clemson, Team 1-3, Hunter Spring 2022
CLEM-HUNTER-S22S1G3
Membros da 5
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 17
Últimos 30 dias: 99
Duração total: 2,662
