Ir para o conteúdo principal
Lenovo ThinkPad T530 External Battery Replacement
O que você precisa
  1. Lenovo ThinkPad T530 External Battery Replacement, Place your laptop upside down: passo 1, imagem 1 %32 Lenovo ThinkPad T530 External Battery Replacement, Place your laptop upside down: passo 1, imagem 2 %32
    • Ensure that the laptop is disconnected from the wall charger, and that the laptop is entirely powered off before following any of the steps below.
    • Flip your laptop upside down, so that the keyboard is facing down.
  2. Lenovo ThinkPad T530 External Battery Replacement, Unlock Battery: passo 2, imagem 1 %32 Lenovo ThinkPad T530 External Battery Replacement, Unlock Battery: passo 2, imagem 2 %32
    • Locate the latch located on the battery near the top of the laptop.
    • Using your finger, slide the latch to the right-most (Unlocked) position.
    • None of this should require an exhuberant amount of force.
  3. Lenovo ThinkPad T530 External Battery Replacement, Remove the Battery: passo 3, imagem 1 %32 Lenovo ThinkPad T530 External Battery Replacement, Remove the Battery: passo 3, imagem 2 %32
    • You can now pull the battery away from the laptop. When pulling the battery out, ensure to pull it out straight.
Conclusão
Uma outra pessoa concluiu este guia.
Documentos anexados
Albert Stoynov
Membro desde: 09/11/23
1.198 Reputação
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 98
