Introdução
This guide will show you how to safely remove the screen from the Lenovo ThinkPad T495s. Before embarking on this process, refer to the link below for troubleshooting monitor issues to avoid unnecessary changes. A screen may need to be removed due to a cracked screen, broken LCD, dysfunctional touch screen, or to access the hardware behind the monitor. To replace a screen, reverse the steps followed in the guide. Use caution when prying off the connections with an iFixit opening tool and tweezer to ensure no further damage.
O que você precisa
Ferramenta utilizada nesse passo:Tweezers$3.99
Use the angled tweezers to lift the adhesive plastic above the connection.
