Introdução
If you need to replace the battery of your Lenovo ThinkPad T495s, follow the steps described below. The battery is one of the most crucial parts of any laptop, and it is one of the most replaced parts as well. A faulty battery might result in your laptop not charging, or not holding a charge. With this guide, you will be able to successfully replace your Lenovo’s internal battery.
Before beginning the repair, be sure to power off your laptop and unplug it from the charger.
O que você precisa
