Introdução
If you have an issue with distorted audio or none at all, then your speaker unit may be damaged or broken, and is in need of replacement. This guide will instruct you on how to replace your speaker unit for the Lenovo Thinkpad T495.
O que você precisa
Grip the speaker cable as close as possible to its motherboard plug, and pull directly backwards, parallel to the motherboard, until the plug releases.
Quase terminado!
Conclusão
