Introdução
Use this guide to replace the bottom cover of your Lenovo ThinkPad T480s laptop.
The bottom cover encloses the internal components of the laptop and provides proper ventilation for the fan. You may need to replace the bottom cover if it is cracked or physically damaged to the point where it is exposing the laptop’s internals.
Make sure to disable the internal battery, power down your device, and disconnect from any external power sources before you begin.
O que você precisa
