Ir para o conteúdo principal
Lenovo ThinkPad T470S Keyboard Replacement
O que você precisa
  1. Lenovo ThinkPad T470S Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Loosen the screw on the backside of the laptop that holds the keyboard in using a Phillips #000 screwdriver.
  2. Lenovo ThinkPad T470S Keyboard Replacement: passo 2, imagem 1 %32
    • Open the laptop.
    • Use a spudger to slide the keyboard cover towards the screen.
  3. Lenovo ThinkPad T470S Keyboard Replacement: passo 3, imagem 1 %32
    • Unscrew the six exposed screws with the Phillips #000 screwdriver.
    • Use the spudger to pop the keyboard out.
  4. Lenovo ThinkPad T470S Keyboard Replacement: passo 4, imagem 1 %32 Lenovo ThinkPad T470S Keyboard Replacement: passo 4, imagem 2 %32 Lenovo ThinkPad T470S Keyboard Replacement: passo 4, imagem 3 %32
    • Flip over the top of the keyboard by the display.
    • Potential for device damage: Use caution when flipping the keyboard over; it is still attached to the rest of the laptop with ribbon cables.
    • Open the retaining flaps on the ribbon cable connectors.
    • Slide the ribbon cables out of their connectors.
    • Remove the keyboard from the device.
Conclusão
5 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 30
Últimos 30 dias: 208
Duração total: 6,570
