Ir para o conteúdo principal
Lenovo ThinkPad T470S Batteries Replacement
O que você precisa
  1. Lenovo ThinkPad T470S Batteries Replacement, Bottom Panel: passo 1, imagem 1 %32
    • Use a Phillips #000 screwdriver to remove the five 7 mm screws from the bottom of the laptop.
    • Lift the bottom panel up and off the laptop.
  2. Lenovo ThinkPad T470S Batteries Replacement, Batteries: passo 2, imagem 1 %32 Lenovo ThinkPad T470S Batteries Replacement, Batteries: passo 2, imagem 2 %32 Lenovo ThinkPad T470S Batteries Replacement, Batteries: passo 2, imagem 3 %32
    • Remove two screws on the bottom of the upper battery using a Phillips #000 screwdriver.
    • Remove three screws on the top of the lower battery using a Phillips #000 screwdriver.
    • Peel back connecting supporting tape on each of the batteries.
  3. Lenovo ThinkPad T470S Batteries Replacement: passo 3, imagem 1 %32 Lenovo ThinkPad T470S Batteries Replacement: passo 3, imagem 2 %32 Lenovo ThinkPad T470S Batteries Replacement: passo 3, imagem 3 %32
    • Slide the upper battery out of the device, away from the laptop.
    • Slide the lower battery out of the device, away from the laptop.
Conclusão
7 outras pessoas executaram este guia.
Um comentário
Is the rear battery, battery 1 or 2? It's my battery 2 that won't charge any more. But maybe I should just change them both. Do you sell both of them or just the one?
Trisha Moore - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 22
Últimos 7 dias: 152
Últimos 30 dias: 781
Duração total: 27,159
