Ir para o conteúdo principal
Lenovo ThinkPad T460s RAM Replacement
O que você precisa
  1. Lenovo ThinkPad T460s RAM Replacement, Battery: passo 1, imagem 1 %32
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Remove the five 5.5mm Phillips #1 screws securing the back cover.
    • These screws are captive and cannot be removed completely from the back cover.
    • Lift and remove the back cover.
  2. Lenovo ThinkPad T460s RAM Replacement: passo 2, imagem 1 %32
    • Remove the five 5.5mm Phillips #1 screws securing the two batteries.
  3. Lenovo ThinkPad T460s RAM Replacement: passo 3, imagem 1 %32
    • Unplug the two-wire connector from the motherboard by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  4. Lenovo ThinkPad T460s RAM Replacement: passo 4, imagem 1 %32 Lenovo ThinkPad T460s RAM Replacement: passo 4, imagem 2 %32 Lenovo ThinkPad T460s RAM Replacement: passo 4, imagem 3 %32
    • Each battery has a black tab covering the electrical contacts.
    • Lift the battery by its tab and remove it from the device.
  5. Lenovo ThinkPad T460s RAM Replacement, RAM: passo 5, imagem 1 %32 Lenovo ThinkPad T460s RAM Replacement, RAM: passo 5, imagem 2 %32 Lenovo ThinkPad T460s RAM Replacement, RAM: passo 5, imagem 3 %32
    • To remove the existing RAM module, pull tabs marked in the red outwards.
Conclusão
3 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 14
Últimos 30 dias: 96
Duração total: 4,657
