Introdução
Use this guide to replace the camera/microphone module in a Lenovo ThinkPad T460 laptop.
The built-in webcam (also called a laptop camera) transmits real-time videos and images to your computer. Some signs of a faulty webcam include error messages that the camera is not enabled or cannot be found, or the camera light is on but the camera itself is unresponsive. If your webcam is physically cracked or damaged, it may require a replacement.
The built-in microphone in this laptop is integrated with the webcam. If your microphone volume is too low, or not audible at all, your microphone may be faulty.
There are known microphone and webcam issues with Windows 10 which may be resolved with these camera and microphone troubleshooting guides.
Before attempting to replace the camera/microphone module, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
O que você precisa
Place the laptop so that the bottom is facing upwards.
Slide the latch on the left side of the battery to the left until it clicks in place.
Loosen the eight captive screws in the bottom cover using a Phillips #1 screwdriver.
Insert the flat end of a spudger in between the bottom cover and the rest of the laptop, starting in the lower left corner.
Pry the lower left corner of the bottom cover up by a few millimeters.
Slide the spudger along the bottom of the laptop to release the clips until you reach the lower right corner.
Remove the two 3.7 mm screws from the LCD cable bracket using a Phillips #1 screwdriver.
Use your hands to peel up the thin LCD bezel sheet from the rest of the display, starting in the area between the hinges.
Use your hands to continue peeling the bezel sheet away from the left side of the laptop.
Use both hands to lift the bottom corners of the display panel
Gently flip the display panel over.
Use the flat end of a spudger to disconnect the cable from the camera/microphone module.
Uma outra pessoa concluiu este guia.
