Ir para o conteúdo principal
Lenovo ThinkPad T440p Keyboard Replacement
O que você precisa
  1. Lenovo ThinkPad T440p Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Flip the laptop so that the back is facing up.
    Pergunte ao FixBot
  2. Lenovo ThinkPad T440p Keyboard Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad T440p Keyboard Replacement: passo 2, imagem 2 %32
    • Slide the battery latches to the unlocked position.
    Pergunte ao FixBot
  3. Lenovo ThinkPad T440p Keyboard Replacement: passo 3, imagem 1 %32 Lenovo ThinkPad T440p Keyboard Replacement: passo 3, imagem 2 %32
    • Slide the battery pack out of the battery slot.
    Pergunte ao FixBot
  4. Lenovo ThinkPad T440p Keyboard Replacement, Keyboard: passo 4, imagem 1 %32 Lenovo ThinkPad T440p Keyboard Replacement, Keyboard: passo 4, imagem 2 %32 Lenovo ThinkPad T440p Keyboard Replacement, Keyboard: passo 4, imagem 3 %32
    • Using the spudger, move the plastic protector by pressing it down and forward in order to uncover the screws.
    Pergunte ao FixBot
  5. Lenovo ThinkPad T440p Keyboard Replacement: passo 5, imagem 1 %32 Lenovo ThinkPad T440p Keyboard Replacement: passo 5, imagem 2 %32
    • Don't remove the screws; just loosen them.
    • Unscrew the six screws that are attached to the keyboard by using a Phillips #00 screwdriver.
    Pergunte ao FixBot
  6. Lenovo ThinkPad T440p Keyboard Replacement: passo 6, imagem 1 %32 Lenovo ThinkPad T440p Keyboard Replacement: passo 6, imagem 2 %32 Lenovo ThinkPad T440p Keyboard Replacement: passo 6, imagem 3 %32
    • Use the spudger to lift the keyboard.
    Pergunte ao FixBot
  7. Lenovo ThinkPad T440p Keyboard Replacement: passo 7, imagem 1 %32 Lenovo ThinkPad T440p Keyboard Replacement: passo 7, imagem 2 %32
    • Turn the keyboard over.
    Pergunte ao FixBot
  8. Lenovo ThinkPad T440p Keyboard Replacement: passo 8, imagem 1 %32 Lenovo ThinkPad T440p Keyboard Replacement: passo 8, imagem 2 %32 Lenovo ThinkPad T440p Keyboard Replacement: passo 8, imagem 3 %32
    • Use the spudger to detach the plastic protection.
    Pergunte ao FixBot
  9. Lenovo ThinkPad T440p Keyboard Replacement: passo 9, imagem 1 %32 Lenovo ThinkPad T440p Keyboard Replacement: passo 9, imagem 2 %32 Lenovo ThinkPad T440p Keyboard Replacement: passo 9, imagem 3 %32
    • Use the spudger to disconnect the cables.
    Pergunte ao FixBot
  10. Lenovo ThinkPad T440p Keyboard Replacement: passo 10, imagem 1 %32
    • Remove the keyboard.
    Pergunte ao FixBot
Conclusão
11 outras pessoas executaram este guia.
Christian Abad
Membro desde: 03/20/19
1.679 Reputação
Autoria de 7 guias
Equipe
1Comentário do guia
Thanks for the guide. I hate this part lol.
is it true if I slip and knock keys off, they can’t be lit in? I’m told this and it seems true :(
Josh Tree - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 88
Ao todo: 8,727
