Introdução
The hard drive is primarily used for the Lenovo ThinkPad T440p’s storage. If your computer is slow, it most likely needs replacing. The replacement is simple and will only require unscrewing screws and using a spudger to lift the hard drive out.
O que você precisa
Use a Phillips #1 screwdriver to remove the two 9mm screws holding the back cover.
7 outras pessoas executaram este guia.
