Ir para o conteúdo principal
Lenovo ThinkPad T440p Fan Replacement
O que você precisa
  1. Lenovo ThinkPad T440p Fan Replacement, Battery: passo 1, imagem 1 %32
    • Flip the laptop so that the back is facing up.
  2. Lenovo ThinkPad T440p Fan Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad T440p Fan Replacement: passo 2, imagem 2 %32
    • Slide the battery latches to the unlocked position.
  3. Lenovo ThinkPad T440p Fan Replacement: passo 3, imagem 1 %32 Lenovo ThinkPad T440p Fan Replacement: passo 3, imagem 2 %32
    • Slide the battery pack out of the battery slot.
  4. Lenovo ThinkPad T440p Fan Replacement, Back Cover: passo 4, imagem 1 %32 Lenovo ThinkPad T440p Fan Replacement, Back Cover: passo 4, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the two 9mm screws holding the back cover.
  5. Lenovo ThinkPad T440p Fan Replacement: passo 5, imagem 1 %32
    • Slide down the back cover.
  6. Lenovo ThinkPad T440p Fan Replacement: passo 6, imagem 1 %32
    • Remove the back cover.
  7. Lenovo ThinkPad T440p Fan Replacement, Fan: passo 7, imagem 1 %32 Lenovo ThinkPad T440p Fan Replacement, Fan: passo 7, imagem 2 %32
    • Using the spudger detach the cable that is connected to the computer.
  8. Lenovo ThinkPad T440p Fan Replacement: passo 8, imagem 1 %32 Lenovo ThinkPad T440p Fan Replacement: passo 8, imagem 2 %32
    • Remove the tape that is over the cable.
  9. Lenovo ThinkPad T440p Fan Replacement: passo 9, imagem 1 %32 Lenovo ThinkPad T440p Fan Replacement: passo 9, imagem 2 %32 Lenovo ThinkPad T440p Fan Replacement: passo 9, imagem 3 %32
    • Screws are attached to the heat sink. Do not try to remove them; just have the screws loosened.
    • Unscrew the four screws that are attached to the heat sink by using a Phillips #0 screwdriver.
  10. Lenovo ThinkPad T440p Fan Replacement: passo 10, imagem 1 %32 Lenovo ThinkPad T440p Fan Replacement: passo 10, imagem 2 %32 Lenovo ThinkPad T440p Fan Replacement: passo 10, imagem 3 %32
    • Remove the fan.
Conclusão
Uma outra pessoa concluiu este guia.
Christian Abad
Membro desde: 03/20/19
1.378 Reputação
Autoria de 7 guias
Equipe
UMass Dartmouth, Team S6-G5, Peak Spring 2019 Membro de UMass Dartmouth, Team S6-G5, Peak Spring 2019
UMASSD-PEAK-S19S6G5
Membros da 3
Autoria de 9 guias
Um comentário
The guide could go one step further as this model features a replaceable CPU.
cubytus - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 16
Últimos 30 dias: 54
Duração total: 3,596
