Ir para o conteúdo principal
Lenovo ThinkPad T440p Display Replacement
O que você precisa
  1. Lenovo ThinkPad T440p Display Replacement, Display: passo 1, imagem 1 %32 Lenovo ThinkPad T440p Display Replacement, Display: passo 1, imagem 2 %32
    • Flip the laptop over so that the bottom of the laptop is facing you.
  2. Lenovo ThinkPad T440p Display Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad T440p Display Replacement: passo 2, imagem 2 %32
    • Slide each of the battery latches away from each other into the unlocked location.
  3. Lenovo ThinkPad T440p Display Replacement: passo 3, imagem 1 %32 Lenovo ThinkPad T440p Display Replacement: passo 3, imagem 2 %32
    • Slide the battery out of the battery compartment.
  4. Lenovo ThinkPad T440p Display Replacement: passo 4, imagem 1 %32 Lenovo ThinkPad T440p Display Replacement: passo 4, imagem 2 %32
    • Flip the laptop over so that the top of the laptop faces you.
  5. Lenovo ThinkPad T440p Display Replacement: passo 5, imagem 1 %32 Lenovo ThinkPad T440p Display Replacement: passo 5, imagem 2 %32
    • Lift the lid of the laptop until the top of the lid is touching the ground.
  6. Lenovo ThinkPad T440p Display Replacement: passo 6, imagem 1 %32 Lenovo ThinkPad T440p Display Replacement: passo 6, imagem 2 %32 Lenovo ThinkPad T440p Display Replacement: passo 6, imagem 3 %32
    • Carefully pry the display bezels away from the display using the plastic opening tool.
    • The edges on the underside of the bezel that touches the display may be sharp.
  7. Lenovo ThinkPad T440p Display Replacement: passo 7, imagem 1 %32 Lenovo ThinkPad T440p Display Replacement: passo 7, imagem 2 %32
    • Use the Phillips #0 screwdriver to remove the four 3mm display screws.
  8. Lenovo ThinkPad T440p Display Replacement: passo 8, imagem 1 %32
    • Carefully lift the display up and place it on the keyboard.
    • Don't remove it from the laptop. There's a cable still attached to it.
  9. Lenovo ThinkPad T440p Display Replacement: passo 9, imagem 1 %32 Lenovo ThinkPad T440p Display Replacement: passo 9, imagem 2 %32 Lenovo ThinkPad T440p Display Replacement: passo 9, imagem 3 %32
    • Locate the latch attached to the display cable.
    • Grab the latch and flip it over so that it is facing away from you.
  10. Lenovo ThinkPad T440p Display Replacement: passo 10, imagem 1 %32
    • Gently remove the cable from the display by pulling it directly away from you.
  11. Lenovo ThinkPad T440p Display Replacement: passo 11, imagem 1 %32 Lenovo ThinkPad T440p Display Replacement: passo 11, imagem 2 %32
    • Remove the display from the computer.
Conclusão
5 outras pessoas executaram este guia.
Rasheed Adam
Membro desde: 07/27/20
337 Reputação
Autoria de 1 guia
Equipe
2 comentários
Easy peasy! Got a fresh 1080p IPS display into my ThinkPad thanks to this guide!
Noah - Responder
What display did you have before? I have heard that there are two different display cables and if you didn't already have a 900p screen/already had a 768p screen, then you will need a new display cable to do the FHD display swap.
Annika Genisis -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 15
Últimos 30 dias: 101
Duração total: 3,095
