Introdução
The back cover is the protective layer for your computer that covers many components that will likely be replaced. The process is very simple and you will only need to remove two screws with a Phillips #1 screw driver.
O que você precisa
Use a Phillips #1 screwdriver to remove the two 9mm screws holding the back cover.
Uma outra pessoa concluiu este guia.
