Introdução
This guide will show you how to locate and replace the Lenovo T431s hard drive. The hard drive is responsible for storage of your computer’s processing and operating files and raw data. If you are experiencing slow processing speeds, glitches, or lack of file space, you might need a new hard drive.
O que você precisa
Use a Phillips #1 screwdriver to remove the eight 5.0 mm screws from the panel.
After loosening the screws, use the three opening tools to take the back panel off of the rest of the device.
