Ir para o conteúdo principal
Lenovo ThinkPad T431S Hard Drive Replacement
O que você precisa
  1. Lenovo ThinkPad T431S Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32 Lenovo ThinkPad T431S Hard Drive Replacement, Hard Drive: passo 1, imagem 2 %32 Lenovo ThinkPad T431S Hard Drive Replacement, Hard Drive: passo 1, imagem 3 %32
    • Remember before starting any disassembly, to prevent electric shock or harm, disconnect the laptop from any external power source and make sure device is powered off.
    • Use a Phillips #1 screwdriver to remove the eight 5.0 mm screws from the panel.
    • After loosening the screws, use the three opening tools to take the back panel off of the rest of the device.
  2. Lenovo ThinkPad T431S Hard Drive Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad T431S Hard Drive Replacement: passo 2, imagem 2 %32 Lenovo ThinkPad T431S Hard Drive Replacement: passo 2, imagem 3 %32
    • Remove the single 3 mm screw holding hard drive bracket in place.
    • Grasp the hard drive and remove it from its bracket.
    • Use a slight wiggle motion to carefully disconnect it from the front prong.
Conclusão
Um comentário
Can I add SSD without removing HDD? in Lenovo T431s?
Usama Khan - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 31
Ao todo: 758
