Ir para o conteúdo principal
Lenovo ThinkPad T431S Fan Replacement
O que você precisa
  1. Lenovo ThinkPad T431S Fan Replacement, Fan: passo 1, imagem 1 %32 Lenovo ThinkPad T431S Fan Replacement, Fan: passo 1, imagem 2 %32
    • Remember before starting any disassembly, to prevent electric shock or harm, disconnect from any external power source and make sure device is powered off.
    • Use a Phillips #1 screwdriver bit to remove eight 5.0 mm screws from the back panel.
    • Carefully pry off the back panel using the opening tool.
  2. Lenovo ThinkPad T431S Fan Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad T431S Fan Replacement: passo 2, imagem 2 %32
    • Use a Phillips #1 screwdriver bit and remove the four 3.0 mm screws from the heatsink.
  3. Lenovo ThinkPad T431S Fan Replacement: passo 3, imagem 1 %32 Lenovo ThinkPad T431S Fan Replacement: passo 3, imagem 2 %32 Lenovo ThinkPad T431S Fan Replacement: passo 3, imagem 3 %32
    • Disconnect the cable attached to the fan, pulling the connector straight down.
    • Lift and remove the fan.
Conclusão
Um comentário
Well done. I will have a go at fixing the fan on my T430s now that I’ve seen how easy it is to do.
Jocko - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 335
