Ir para o conteúdo principal
Lenovo ThinkPad T431S Charging Port Replacement
O que você precisa
  1. Lenovo ThinkPad T431S Charging Port Replacement, Charging Port: passo 1, imagem 1 %32 Lenovo ThinkPad T431S Charging Port Replacement, Charging Port: passo 1, imagem 2 %32
    • Remember before starting any disassembly, to prevent electric shock or harm, disconnect from any external power source and make sure device is powered off.
    • Use a Phillips #1 screwdriver bit to remove eight 5.0 mm screws from the back panel.
    • After loosening the screws, use the three opening tools to take the back panel off of the rest of the device.
  2. Lenovo ThinkPad T431S Charging Port Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad T431S Charging Port Replacement: passo 2, imagem 2 %32
    • Unscrew the single, 3.0 mm screw with a Phillips #1 screwdriver bit that holds the charging port housing into place.
  3. Lenovo ThinkPad T431S Charging Port Replacement: passo 3, imagem 1 %32 Lenovo ThinkPad T431S Charging Port Replacement: passo 3, imagem 2 %32
    • Remove the small, white connector cable by prying it from the connector with a plastic opening tool.
    • Remove the charging port assembly.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 36
Duração total: 4,000
