Introdução
This is a replacement guide for the built-in trackpad and mouse keys on the Lenovo ThinkPad T430s. The keyboard and the trackpad are the two user inputs that are necessary to interact with a laptop. A faulty keyboard or mouse may not respond to user input. However, a faulty mouse and/or keyboard can also be stuck inputting the same value over and over. This guide requires that the motherboard is taken from the laptop case. Ensure that the battery is fully removed before doing any work on the internal wiring.
O que você precisa
Flip your ThinkPad on its back.
In the bottom left corner of your ThinkPad, slide the lever to the left. Hold the lever there.
Use your other hand to lift the battery up by prying the notch to the left of the lever.
Tilt the battery up and remove it from the ThinkPad.
With the Phillips #0 screwdriver, loosen the two 30 mm screws holding down the RAM stick plate.
Pry up the plate and set it aside.
Flip your ThinkPad over so the back faces up.
With the Phillips #0 screwdriver, remove the seven 50 mm screws on the outer edge of the case.
Remove the two 70 mm screws in the upper corners of the case.
Remove the five 50 mm screws in the battery compartment.
In the RAM compartment, pry the black, white, and grey wires up from the Wi-Fi card with the pointy end of the spudger.
Remove the 30 mm screw holding down the Wi-Fi card with the Phillips #0 screwdriver.
Pull out the Wi-Fi card.
Remove the 60 mm and 30 mm screws in the RAM stick compartment.
Flip the ThinkPad right side up and open the lid.
Wedge the flat end of the spudger between the keyboard and the palm rest. Push the keyboard away from you until it pops out.
Lift the keyboard from the palm rest to expose the ribbon connecting the keyboard to the motherboard.
Pry the keyboard ribbon up from the motherboard with the flat end of the spudger.
Set the keyboard aside.
Remove the two 50 mm screws from the case covering the disk drive.
Thread the wires that come from the RAM compartment up through the hole in the motherboard. Unwind them from the computer case.
Wedge the flat end of the spudger in between the palm rest and the bottom case. Unsnap the edges of the palm rest and case until they disconnect.
Lift the palm rest up from the motherboard.
Return to the case and place it so the keyboard is facing down.
Peel the protective coating back from the trackpad.
Remove the coating and set it aside.
