Ir para o conteúdo principal
Lenovo ThinkPad T430s Fan Assembly Replacement
O que você precisa
  1. Lenovo ThinkPad T430s Fan Assembly Replacement, Battery: passo 1, imagem 1 %32 Lenovo ThinkPad T430s Fan Assembly Replacement, Battery: passo 1, imagem 2 %32 Lenovo ThinkPad T430s Fan Assembly Replacement, Battery: passo 1, imagem 3 %32
    • Flip your ThinkPad on its back.
    • In the bottom left corner of your ThinkPad, slide the lever to the left. Hold the lever there.
    • Use your other hand to lift the battery up by prying the notch to the left of the lever.
    • Tilt the battery up and remove it from the ThinkPad.
  2. Lenovo ThinkPad T430s Fan Assembly Replacement, RAM Stick: passo 2, imagem 1 %32 Lenovo ThinkPad T430s Fan Assembly Replacement, RAM Stick: passo 2, imagem 2 %32 Lenovo ThinkPad T430s Fan Assembly Replacement, RAM Stick: passo 2, imagem 3 %32
    • With the Phillips #0 screwdriver, loosen the two 30 mm screws holding down the RAM stick plate.
    • Pry up the plate and set it aside.
  3. Lenovo ThinkPad T430s Fan Assembly Replacement: passo 3, imagem 1 %32 Lenovo ThinkPad T430s Fan Assembly Replacement: passo 3, imagem 2 %32 Lenovo ThinkPad T430s Fan Assembly Replacement: passo 3, imagem 3 %32
    • Use the pointy end of the spudger to bend the bars holding the RAM stick in place.
    • Lift the RAM stick up and out of the stick holder.
  4. Lenovo ThinkPad T430s Fan Assembly Replacement, Hard Drive: passo 4, imagem 1 %32
    • Unscrew the 40 mm screw with the Phillips head #1 screwdriver.
  5. Lenovo ThinkPad T430s Fan Assembly Replacement: passo 5, imagem 1 %32
    • Pull the hard drive out with the black ribbon attached to it.
  6. Lenovo ThinkPad T430s Fan Assembly Replacement, Motherboard: passo 6, imagem 1 %32 Lenovo ThinkPad T430s Fan Assembly Replacement, Motherboard: passo 6, imagem 2 %32 Lenovo ThinkPad T430s Fan Assembly Replacement, Motherboard: passo 6, imagem 3 %32
    • Flip your ThinkPad over so the back faces up.
    • With the Phillips #0 screwdriver, remove the seven 50 mm screws on the outer edge of the case.
    • Remove the two 70 mm screws in the upper corners of the case.
    • Remove the five 50 mm screws in the battery compartment.
  7. Lenovo ThinkPad T430s Fan Assembly Replacement: passo 7, imagem 1 %32 Lenovo ThinkPad T430s Fan Assembly Replacement: passo 7, imagem 2 %32 Lenovo ThinkPad T430s Fan Assembly Replacement: passo 7, imagem 3 %32
    • In the RAM compartment, pry the black, white, and grey wires up from the Wi-Fi card with the pointy end of the spudger.
    • Remove the 30 mm screw holding down the Wi-Fi card with the Phillips #0 screwdriver.
    • Pull out the Wi-Fi card.
    • Remove the 60 mm and 30 mm screws in the RAM stick compartment.
  8. Lenovo ThinkPad T430s Fan Assembly Replacement: passo 8, imagem 1 %32
    • Remove the 50 mm and 30 mm screws in the hard drive compartment.
  9. Lenovo ThinkPad T430s Fan Assembly Replacement: passo 9, imagem 1 %32 Lenovo ThinkPad T430s Fan Assembly Replacement: passo 9, imagem 2 %32 Lenovo ThinkPad T430s Fan Assembly Replacement: passo 9, imagem 3 %32
    • Flip the ThinkPad right side up and open the lid.
    • Wedge the flat end of the spudger between the keyboard and the palm rest. Push the keyboard away from you until it pops out.
    • Lift the keyboard from the palm rest to expose the ribbon connecting the keyboard to the motherboard.
    • Pry the keyboard ribbon up from the motherboard with the flat end of the spudger.
    • Set the keyboard aside.
  10. Lenovo ThinkPad T430s Fan Assembly Replacement: passo 10, imagem 1 %32 Lenovo ThinkPad T430s Fan Assembly Replacement: passo 10, imagem 2 %32 Lenovo ThinkPad T430s Fan Assembly Replacement: passo 10, imagem 3 %32
    • Remove the two 50 mm screws from the case covering the disk drive.
    • Thread the wires that come from the RAM compartment up through the hole in the motherboard. Unwind them from the computer case.
    • Wedge the flat end of the spudger in between the palm rest and the bottom case. Unsnap the edges of the palm rest and case until they disconnect.
    • Lift the palm rest up from the motherboard.
  11. Lenovo ThinkPad T430s Fan Assembly Replacement: passo 11, imagem 1 %32 Lenovo ThinkPad T430s Fan Assembly Replacement: passo 11, imagem 2 %32 Lenovo ThinkPad T430s Fan Assembly Replacement: passo 11, imagem 3 %32
    • Pull the red, blue, and white wires in the left corner away from the motherboard.
    • Peel the snap securing the ribbon with the pointy end of the spudger.
    • Pull the ribbon back towards you.
  12. Lenovo ThinkPad T430s Fan Assembly Replacement: passo 12, imagem 1 %32 Lenovo ThinkPad T430s Fan Assembly Replacement: passo 12, imagem 2 %32 Lenovo ThinkPad T430s Fan Assembly Replacement: passo 12, imagem 3 %32
    • Rotate the ThinkPad so the back side faces you.
    • With the Phillips #1 screwdriver, unscrew the two 70 mm screws from the corners.
    • Lift the screen and pull it out of the hinges. Set the screen down behind the rest of the ThinkPad.
  13. Lenovo ThinkPad T430s Fan Assembly Replacement: passo 13, imagem 1 %32 Lenovo ThinkPad T430s Fan Assembly Replacement: passo 13, imagem 2 %32 Lenovo ThinkPad T430s Fan Assembly Replacement: passo 13, imagem 3 %32
    • With the pointy end of the spudger, lift the plastic snap holding down the SN4 LVDS cable. Pull the cable out of the clasp towards you.
    • Pry the SN4 LED cable out of where it connects to the motherboard.
    • Set the display aside.
  14. Lenovo ThinkPad T430s Fan Assembly Replacement: passo 14, imagem 1 %32 Lenovo ThinkPad T430s Fan Assembly Replacement: passo 14, imagem 2 %32 Lenovo ThinkPad T430s Fan Assembly Replacement: passo 14, imagem 3 %32
    • With the pointy end of the spudger, lift the plastic snap securing the ribbon at the front of the ThinkPad.
    • Pull the ribbon out of the clasp towards you.
  15. Lenovo ThinkPad T430s Fan Assembly Replacement: passo 15, imagem 1 %32 Lenovo ThinkPad T430s Fan Assembly Replacement: passo 15, imagem 2 %32 Lenovo ThinkPad T430s Fan Assembly Replacement: passo 15, imagem 3 %32
    • Unscrew the 90 mm screw, five 50 mm screws, and four 30 mm screws on the motherboard using a Phillips #0 screwdriver.
    • When you remove the screws, the small motherboard stick in the top right corner will pop out of the case. Pull it out.
    • Lift the motherboard out of the case.
  16. Lenovo ThinkPad T430s Fan Assembly Replacement: passo 16, imagem 1 %32 Lenovo ThinkPad T430s Fan Assembly Replacement: passo 16, imagem 2 %32 Lenovo ThinkPad T430s Fan Assembly Replacement: passo 16, imagem 3 %32
    • Flip the motherboard over so the back faces up.
    • Loosen the four screws securing the heat sink to the motherboard. The silver metal rectangle on the front of the motherboard will fall off. Set it aside.
    • Lift the fan and heat sink away from the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 65
Duração total: 790
