Ir para o conteúdo principal
Lenovo ThinkPad T430s Display Replacement
O que você precisa
  1. Lenovo ThinkPad T430s Display Replacement, Battery: passo 1, imagem 1 %32 Lenovo ThinkPad T430s Display Replacement, Battery: passo 1, imagem 2 %32 Lenovo ThinkPad T430s Display Replacement, Battery: passo 1, imagem 3 %32
    • Flip your ThinkPad on its back.
    • In the bottom left corner of your ThinkPad, slide the lever to the left. Hold the lever there.
    • Use your other hand to lift the battery up by prying the notch to the left of the lever.
    • Tilt the battery up and remove it from the ThinkPad.
  2. Lenovo ThinkPad T430s Display Replacement, Display: passo 2, imagem 1 %32 Lenovo ThinkPad T430s Display Replacement, Display: passo 2, imagem 2 %32 Lenovo ThinkPad T430s Display Replacement, Display: passo 2, imagem 3 %32
    • Rotate your ThinkPad so the back side faces you.
    • With the Phillips #1 screwdriver, remove the two 70 mm screws in the right and left corners. These may be covered by plastic covers.
    • Open the ThinkPad so the screen faces up. Lift the screen from its hinges.
  3. Lenovo ThinkPad T430s Display Replacement: passo 3, imagem 1 %32 Lenovo ThinkPad T430s Display Replacement: passo 3, imagem 2 %32 Lenovo ThinkPad T430s Display Replacement: passo 3, imagem 3 %32
    • With the Phillips #0 screwdriver, remove the two 50 mm screws securing the plastic display case.
    • Wedge the flat end of the spudger in between the display case and the screen. Unsnap the top case from the bottom piece holding the screen.
    • Remove the case and set it aside.
  4. Lenovo ThinkPad T430s Display Replacement: passo 4, imagem 1 %32 Lenovo ThinkPad T430s Display Replacement: passo 4, imagem 2 %32 Lenovo ThinkPad T430s Display Replacement: passo 4, imagem 3 %32
    • Unscrew the four 30 mm screws holding the screen to the case.
    • Lift the screen out of the case.
    • Flip the screen over.
  5. Lenovo ThinkPad T430s Display Replacement: passo 5, imagem 1 %32 Lenovo ThinkPad T430s Display Replacement: passo 5, imagem 2 %32 Lenovo ThinkPad T430s Display Replacement: passo 5, imagem 3 %32
    • Peel away the tape holding the cable down with the flat end of the spudger.
    • Pull the cable out of its socket.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 13
Últimos 30 dias: 63
Duração total: 2,478
