Ir para o conteúdo principal
Lenovo ThinkPad T420s LCD Replacement
O que você precisa
  1. Lenovo ThinkPad T420s LCD Replacement, Keyboard: passo 1, imagem 1 %32 Lenovo ThinkPad T420s LCD Replacement, Keyboard: passo 1, imagem 2 %32
    • Flip your laptop over so the bottom is facing up.
    • Remove the memory panel by removing two black 5mm screws using the Phillips #0.
    • Remove the memory panel.
  2. Lenovo ThinkPad T420s LCD Replacement: passo 2, imagem 1 %32
    • Remove the two 5mm screw using the Phillips #0 screwdriver.
    • Flip the laptop back over and open it.
  3. Lenovo ThinkPad T420s LCD Replacement: passo 3, imagem 1 %32 Lenovo ThinkPad T420s LCD Replacement: passo 3, imagem 2 %32 Lenovo ThinkPad T420s LCD Replacement: passo 3, imagem 3 %32
    • Gently push down on the keyboard and slide it towards the screen. This will pop the bottom of the keyboard out of the casing.
    • The best place to push is on the frame of the keyboard by the power button.
    • Using the metal spudger, lift and slide out the keyboard.
    • When lifting the keyboard do not remove it completely because a cable will still be connected to the laptop.
  4. Lenovo ThinkPad T420s LCD Replacement: passo 4, imagem 1 %32
    • Remove the orange cable by lifting up on the tab on the end of the ribbon connection.
  5. Lenovo ThinkPad T420s LCD Replacement, Palm Rest: passo 5, imagem 1 %32
    • Remove the additional thirteen 5 mm screws with your Phillips #0 screwdriver.
    • Remove the two 2.5 X 5 mm screws from the back of your laptop.
    • 2.5 X 5 mm screws are slightly larger than the 5 mm screws.
    • Remove the 3 mm screw from the back of the laptop using the same screwdriver.
  6. Lenovo ThinkPad T420s LCD Replacement: passo 6, imagem 1 %32
    • Disconnect the black and gray antenna cable connectors in the memory panel on the back of the laptop.
    • Remove any plastic wraps on the blue, white, and tan wires.
  7. Lenovo ThinkPad T420s LCD Replacement: passo 7, imagem 1 %32
    • Flip the laptop back over and pull all the wires from the previous step through to the top side.
  8. Lenovo ThinkPad T420s LCD Replacement: passo 8, imagem 1 %32
    • Remove the three 5mm screws holding the palm rest casing in place using the Phillips #0.
  9. Lenovo ThinkPad T420s LCD Replacement: passo 9, imagem 1 %32
    • Unplug the red, white, and blue bunch of wires.
  10. Lenovo ThinkPad T420s LCD Replacement: passo 10, imagem 1 %32
    • Lift up the black retaining flap holding the purple ribbon cable in place, and carefully slide out the ribbon.
  11. Lenovo ThinkPad T420s LCD Replacement: passo 11, imagem 1 %32
    • Remove the top casing by lifting up and sliding out.
    • Be careful when sliding the casing out as some of the casing is still underneath the screen; some wiggling may be required, but do not force it.
  12. Lenovo ThinkPad T420s LCD Replacement, LCD: passo 12, imagem 1 %32 Lenovo ThinkPad T420s LCD Replacement, LCD: passo 12, imagem 2 %32
    • Unplug the two black cables that connect the screen to the motherboard.
  13. Lenovo ThinkPad T420s LCD Replacement: passo 13, imagem 1 %32 Lenovo ThinkPad T420s LCD Replacement: passo 13, imagem 2 %32
    • Flip your laptop so the back-side is facing towards you.
    • Remove any black stickers covering the screws using the nylon or metal spudger.
    • Remove the two 7mm screws using the Phillips #0 screwdriver.
  14. Lenovo ThinkPad T420s LCD Replacement: passo 14, imagem 1 %32
    • Remove the LCD screen unit by holding the sides and lifting it upwards.
Conclusão
14 outras pessoas executaram este guia.
Alex Cabrera
Membro desde: 04/14/15
650 Reputação
2 Guias de autoria
Equipe
Cal Poly, Team 6-13, Maness Spring 2015 Membro de Cal Poly, Team 6-13, Maness Spring 2015
CPSU-MANESS-S15S6G13
4 Membros
5 Guias de autoria
4 comentários
This is not the Lenovo Thinkpad T420. You can Tell by the RAM memory Slot Cover and the Position the RAM is put into its slot. the T420 RAM is Vertical Compared with being Horizontal in this Picture. that includes the cover also. Then the Battery Slot is a Dead Giveaway clue. The T420 Battery slot is in the middle. and this Picture has the battery slot to bthe left. Sorry Not Even Close. None of the screws he removes are on the T420. so this is Completely Useless. Thanks
Keith Cloward - Responder
It is however a Lenovo ThinkPad T420S as the title suggests. So it is quite useful. :-)
Michael Parry -
Yes, the T420 is slightly different to the T420s. But if you find this instruction useless, then you should better not touch any laptop and make repairs yourself, if you don’t cope with a slightly different model…
Andreas Kaufmann -
I would be nice to go down to screen level. Show how to remove bezel as most screen replacements retain the original surrounds. The T420 and T420s are often bone-yarded and this is a common fix where the screen is good but the hinges or frame are U/S.
Matthew McKenzie - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 80
Duração total: 12,518
