Ir para o conteúdo principal
Lenovo ThinkPad T400s LCD Screen Replacement
O que você precisa
  1. Lenovo ThinkPad T400s LCD Screen Replacement, LCD Screen: passo 1, imagem 1 %32
    • Use a #0 Phillips head screwdriver to remove the two 3mm screws that hold the screen bezel in place.
  2. Lenovo ThinkPad T400s LCD Screen Replacement: passo 2, imagem 1 %32
    • Using the plastic opening tool, gently pry off the plastic LCD screen frame around the entire perimeter.
    • Be careful while prying the frame off, because the plastic tabs that hold it in may break.
  3. Lenovo ThinkPad T400s LCD Screen Replacement: passo 3, imagem 1 %32 Lenovo ThinkPad T400s LCD Screen Replacement: passo 3, imagem 2 %32
    • Remove the LCD connector by pulling on the ribbon cable at the connection.
  4. Lenovo ThinkPad T400s LCD Screen Replacement: passo 4, imagem 1 %32
    • Lift the LCD screen out to replace.
    • Make sure to remove the screen with both hands and from opposite edges of the screen.
Conclusão
7 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 6-18, Maness Spring 2015 Membro de Cal Poly, Team 6-18, Maness Spring 2015
CPSU-MANESS-S15S6G18
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 15
Duração total: 2,548
