Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove the Phillips #0-6mm screw.
Lift up the back cover to the RAM cards.
Pull the lock for the baterry to the left to unlock.
While holding the tab in the unlocked position, remove the battery.
Remove the three Phillips #0-6mm screws on the back panel.
Turn the computer over and open the lid.
Wedge the small metal spudger between the palm rest and the keyboard.
Lift up the keyboard, but be careful not to completely remove.
Wedge the small plastic opening tool underneath copper band and tilt back.
Remove keyboard to replace.
