Ir para o conteúdo principal
Lenovo ThinkPad T400s Keyboard Replacement
O que você precisa
  1. Lenovo ThinkPad T400s Keyboard Replacement, Keyboard: passo 1, imagem 1 %32 Lenovo ThinkPad T400s Keyboard Replacement, Keyboard: passo 1, imagem 2 %32
    • Remove the Phillips #0-6mm screw.
    • Lift up the back cover to the RAM cards.
  2. Lenovo ThinkPad T400s Keyboard Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad T400s Keyboard Replacement: passo 2, imagem 2 %32
    • Pull the lock for the baterry to the left to unlock.
    • While holding the tab in the unlocked position, remove the battery.
  3. Lenovo ThinkPad T400s Keyboard Replacement: passo 3, imagem 1 %32
    • Remove the three Phillips #0-6mm screws on the back panel.
    • These screws are marked with a keyboard symbol next to them.
  4. Lenovo ThinkPad T400s Keyboard Replacement: passo 4, imagem 1 %32 Lenovo ThinkPad T400s Keyboard Replacement: passo 4, imagem 2 %32 Lenovo ThinkPad T400s Keyboard Replacement: passo 4, imagem 3 %32
    • Turn the computer over and open the lid.
    • Wedge the small metal spudger between the palm rest and the keyboard.
  5. Lenovo ThinkPad T400s Keyboard Replacement: passo 5, imagem 1 %32 Lenovo ThinkPad T400s Keyboard Replacement: passo 5, imagem 2 %32 Lenovo ThinkPad T400s Keyboard Replacement: passo 5, imagem 3 %32
    • Lift up the keyboard, but be careful not to completely remove.
    • Don't lift the keyboard too quickly, there is a connector cable you must disconnect first.
    • Wedge the small plastic opening tool underneath copper band and tilt back.
    • Remove keyboard to replace.
Conclusão
Morgan Montalvo
Membro desde: 04/14/15
652 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 6-18, Maness Spring 2015 Membro de Cal Poly, Team 6-18, Maness Spring 2015
CPSU-MANESS-S15S6G18
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 1,461
