Ir para o conteúdo principal
Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement
O que você precisa
  1. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement, Hard Disk Drive: passo 1, imagem 1 %32 Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement, Hard Disk Drive: passo 1, imagem 2 %32
    • Remove the 8 screws that hold down the back panel using the Phillips #000 screwdriver.
  2. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: passo 2, imagem 1 %32
    • Remove the two M2 x 3 mm, wafer-head, nylon-coated screws that hold down the hard drive assembly using the Phillips #0 screwdriver.
  3. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: passo 3, imagem 1 %32
    • Pull the hard drive assembly out with backside up.
  4. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: passo 4, imagem 1 %32
    • Remove the four M3 x 3 mm, flat-head, nylon-coated screws on the side of the hard drive assembly using the Phillips #0 screwdriver.
  5. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: passo 5, imagem 1 %32
    • Gently, remove the plastic cover with the blue strips.
  6. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement, HDMI-USB Jack assembly: passo 6, imagem 1 %32 Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement, HDMI-USB Jack assembly: passo 6, imagem 2 %32
    • Remove the 3 screws holding down the T shaped cover using the Phillips head #1. Two of the screws are M2.5x 4 wafer head. The other is a M2x4MM.
    • The two similar screws have blue threading around them.
  7. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: passo 7, imagem 1 %32 Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: passo 7, imagem 2 %32
    • Use the opening tool to lift up the T shaped cover.
    • Remove the M2x3MM wafer head screw.
  8. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: passo 8, imagem 1 %32 Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: passo 8, imagem 2 %32 Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: passo 8, imagem 3 %32
    • Take off the 2 M2x3MM wafered screws holding down the chip top of assembly.
    • Lift the chip to release the HDMI-USB jack assembly
  9. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: passo 9, imagem 1 %32
    • Detach the connector.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 281
