Ir para o conteúdo principal
Lenovo ThinkPad R61 Thermal Paste Replacement
O que você precisa
  1. Lenovo ThinkPad R61 Thermal Paste Replacement, Opening the laptop.: passo 1, imagem 1 %32 Lenovo ThinkPad R61 Thermal Paste Replacement, Opening the laptop.: passo 1, imagem 2 %32 Lenovo ThinkPad R61 Thermal Paste Replacement, Opening the laptop.: passo 1, imagem 3 %32
    • Unscrew all screws from the bottom and unplug the battery.
    • Carefully lift up the touchpad panel and unplug it.
    • Next, carefully lift up the keyboard and unplug it.
  2. Lenovo ThinkPad R61 Thermal Paste Replacement, Getting to the insides.: passo 2, imagem 1 %32 Lenovo ThinkPad R61 Thermal Paste Replacement, Getting to the insides.: passo 2, imagem 2 %32 Lenovo ThinkPad R61 Thermal Paste Replacement, Getting to the insides.: passo 2, imagem 3 %32
    • Remove the screws that hold the speaker panel.
    • Unplug any cables that get in the way of removing it.
    • Unscrew the screws holding the CPU heatsink and fan. Disconnect the fan cable.
    • You can carefully use a plastic prying tool to help yourself remove the heatsink, if it is stuck.
  3. Lenovo ThinkPad R61 Thermal Paste Replacement, Changing the thermal paste and cleaning the fan.: passo 3, imagem 1 %32 Lenovo ThinkPad R61 Thermal Paste Replacement, Changing the thermal paste and cleaning the fan.: passo 3, imagem 2 %32
    • Clean the old thermal paste both from the cooler and the CPU. It is best to use isopropyl alcohol and cotton swabs or paper towel, but be careful not to go too hard on the CPU.
    • You can remove the few screws and carefully open the fan enclosure to clean it further.
  4. Lenovo ThinkPad R61 Thermal Paste Replacement, Applying new thermal paste.: passo 4, imagem 1 %32
    • Dont use too much thermal paste, just enough to cover some portion of the pad. If you have a spreader, use it. The thermal paste will apply evenly after you tighten the heatsink.
    • Last, put the heatsink back carefully and tighten the screws in order to ensure even pressure. Dont forget to plug in the fan cable.
  5. Lenovo ThinkPad R61 Thermal Paste Replacement, Upgrading the RAM and SSD (Optional): passo 5, imagem 1 %32
    • Once you have opened the laptop, it is a good idea to upgrade the RAM or the SSD if you want.
    • It is also recommended to use compressed air to remove any dust in the laptop and the fan.
Conclusão
Uma outra pessoa concluiu este guia.
Simeon Brankov
Membro desde: 11/08/20
7.180 Reputação
Autoria de 54 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 24
Últimos 30 dias: 73
Ao todo: 893
