Ir para o conteúdo principal
Lenovo ThinkPad P52s WiFi Card Replacement
O que você precisa
  1. Lenovo ThinkPad P52s WiFi Card Replacement, Disable Internal Battery: passo 1, imagem 1 %32
    • Interrupt startup by hitting enter, and enter the BIOS by hitting F1.
    • Navigate to Config -> Power, and disable the internal battery.
  2. Lenovo ThinkPad P52s WiFi Card Replacement, Remove Detachable Battery: passo 2, imagem 1 %32
    • Close the lid and flip the unit over. Pull the battery release tabs outwards, then pull the battery out.
  3. Lenovo ThinkPad P52s WiFi Card Replacement, Remove Bottom Plate: passo 3, imagem 1 %32
    • Unscrew the bottom plate.
    • Starting from the corners further from the hinges, carefully run the spudger around the machine releasing the clips holding the bottom plate in place.
  4. Lenovo ThinkPad P52s WiFi Card Replacement, Replace WiFi Card: passo 4, imagem 1 %32
    • Locate the WiFi card, and gently remove the two antenna cables.
    • Remove the screw holding the card in place, and pull the card out. Replace it with the new one.
    • Plug the antenna cables into the new card. The gray one is the main antenna (indicated by solid triangle) and black the auxiliary (indicated by empty triangle).
Conclusão
Prithvi Vishak
Membro desde: 04/04/22
117 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 24
Duração total: 565
