Ir para o conteúdo principal
Lenovo ThinkPad P50s External Battery Replacement
  1. Lenovo ThinkPad P50s External Battery Replacement, Battery: passo 1, imagem 1 %32 Lenovo ThinkPad P50s External Battery Replacement, Battery: passo 1, imagem 2 %32
    • Flip the device over so the bottom is facing you.
  2. Lenovo ThinkPad P50s External Battery Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad P50s External Battery Replacement: passo 2, imagem 2 %32
    • Use your thumb to slide the right lock switch button outward.
  3. Lenovo ThinkPad P50s External Battery Replacement: passo 3, imagem 1 %32 Lenovo ThinkPad P50s External Battery Replacement: passo 3, imagem 2 %32 Lenovo ThinkPad P50s External Battery Replacement: passo 3, imagem 3 %32
    • With your thumb slide the left lock switch button outward while sliding the battery out with your other hand.
    • When replacing the battery, make sure that the connectors are aligned properly.
    • You may hear a click when the battery is fully seated and the lock engages.
Conclusão
Jaylan
Membro desde: 09/09/24
645 Reputação
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 11
Ao todo: 66
