Introdução
How to replace the battery of a Lenovo ThinkPad P1 Gen2 laptop. The images and information in this guide were taken from this computer's service manual.
O que você precisa
Remove the 7 screws holding the base cover in place.
Remove the base cover.
Peel up the insulated sheet from the battery connector.
Unplug the battery connector in the direction showed by the arrow.
Remove the two M2 × L4 mm, flat-head screws.
Remove the two M2 × L5 mm, flat-head, screws.
To replace the battery & reassemble your device, follow these instructions in reverse order.
Uma outra pessoa concluiu este guia.
