Ir para o conteúdo principal
Lenovo ThinkPad P1 Gen2 Laptop Battery Replacement
O que você precisa
  1. Lenovo ThinkPad P1 Gen2 Laptop Battery Replacement, Remove base cover: passo 1, imagem 1 %32
    • Remove the 7 screws holding the base cover in place.
    • Remove the base cover.
  2. Lenovo ThinkPad P1 Gen2 Laptop Battery Replacement, Unplug the battery: passo 2, imagem 1 %32
    • Peel up the insulated sheet from the battery connector.
    • Unplug the battery connector in the direction showed by the arrow.
  3. Lenovo ThinkPad P1 Gen2 Laptop Battery Replacement, Remove the battery screws: passo 3, imagem 1 %32
    • Remove the two M2 × L4 mm, flat-head screws.
    • Remove the two M2 × L5 mm, flat-head, screws.
  4. Lenovo ThinkPad P1 Gen2 Laptop Battery Replacement, Remove the battery: passo 4, imagem 1 %32
    • Remove the battery.
Conclusão
To replace the battery & reassemble your device, follow these instructions in reverse order.
4 outras pessoas executaram este guia.
Max Kletskov
Membro desde: 04/22/20
41.669 Reputação
Autoria de 16 guias
3Comentários do guia
Great Thank you for info
Brad - Responder
Will this battery generate a Bios not authentic battery warning? Other replacement batteries would not charge in my P1 Gen2 ThinkPad.
hello - Responder
Is it compatible for Lenovo Thinkpad P1 Gen1 Type 20MD ?
k2ki - Responder
Comentar
Visualizações:
Últimas 24 horas: 10
Últimos 7 dias: 60
Últimos 30 dias: 241
Ao todo: 15,370
