Ir para o conteúdo principal
Lenovo ThinkPad Helix Screen Replacement
O que você precisa
  1. Lenovo ThinkPad Helix Screen Replacement, Screen: passo 1, imagem 1 %32
    • Using a plastic opening tool or opening pick, gently pry the screen off.
    • If possible, use plastic tools to pry the screen, as the metal tool as shown in the image can potentially damage your device.
    • You will need to use a little bit of force to pry it open. There is little indent that goes around the tablet. You will insert your tool between this indent and pry it open.
    • Once you're able to lift a little bit of the screen away from the tablet, work your way around until screen is separated from tablet. Stop for step two.
  2. Lenovo ThinkPad Helix Screen Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad Helix Screen Replacement: passo 2, imagem 2 %32 Lenovo ThinkPad Helix Screen Replacement: passo 2, imagem 3 %32
    • Lift the screen up slowly.
    • Once separated, you can not fully take it off due to some cable connections.
    • Open the clips of the ZIF connectors and gently grab the cable to pull it out.
  3. Lenovo ThinkPad Helix Screen Replacement: passo 3, imagem 1 %32
    • Once the cables are disconnected, remove the screen.
Conclusão
3 outras pessoas executaram este guia.
Equipe
Gateway, Team S1-G6, Saknee Fall 2019 Membro de Gateway, Team S1-G6, Saknee Fall 2019
GCC-SAKNEE-F19S1G6
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 24
Duração total: 1,668
