Ir para o conteúdo principal
Lenovo ThinkPad Edge E420s Motherboard Replacement
O que você precisa
  1. Lenovo ThinkPad Edge E420s Motherboard Replacement, Hard Drive: passo 1, imagem 1 %32
    • There is no external access to the battery. Please make sure the at the battery has been drained or disabled through BIOS before beginning.
    • Flip the device over.
  2. Lenovo ThinkPad Edge E420s Motherboard Replacement: passo 2, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove one M2 x 3mm screw from the side of the device.
  3. Lenovo ThinkPad Edge E420s Motherboard Replacement: passo 3, imagem 1 %32 Lenovo ThinkPad Edge E420s Motherboard Replacement: passo 3, imagem 2 %32 Lenovo ThinkPad Edge E420s Motherboard Replacement: passo 3, imagem 3 %32
    • Swing the cover out slightly like a hinge.
    • Pull the cover directly away from the case towards the base of the laptop.
    • Lift the cover up and away from the device to remove it.
    • You may hear a slight pop when you pull the cover off.
  4. Lenovo ThinkPad Edge E420s Motherboard Replacement: passo 4, imagem 1 %32
    • Use the clear tab to slide the hard drive out of the device.
  5. Lenovo ThinkPad Edge E420s Motherboard Replacement: passo 5, imagem 1 %32 Lenovo ThinkPad Edge E420s Motherboard Replacement: passo 5, imagem 2 %32 Lenovo ThinkPad Edge E420s Motherboard Replacement: passo 5, imagem 3 %32
    • To replace the hard drive, remove the four M2 × 4mm wafer-headed screws on the sides of the hard drive case using a Phillips #00 screwdriver.
    • Slide the old hard drive directly out.
    • When reassembling, make sure the hard drive is securely in the case before beginning.
  6. Lenovo ThinkPad Edge E420s Motherboard Replacement, Top Case: passo 6, imagem 1 %32 Lenovo ThinkPad Edge E420s Motherboard Replacement, Top Case: passo 6, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove eight M2 × 3 mm screws near the front opening and scattered across the bottom of the laptop.
    • Remove three M2x3 mm screws using a Phillips #00 screwdriver from the base of the laptop near the opening.
  7. Lenovo ThinkPad Edge E420s Motherboard Replacement: passo 7, imagem 1 %32
    • Remove the M3 x 2mm screw from the hole left by the hard drive using a Phillips #00 screwdriver.
  8. Lenovo ThinkPad Edge E420s Motherboard Replacement: passo 8, imagem 1 %32 Lenovo ThinkPad Edge E420s Motherboard Replacement: passo 8, imagem 2 %32
    • Flip over the device.
    • Open the device normally.
  9. Lenovo ThinkPad Edge E420s Motherboard Replacement: passo 9, imagem 1 %32
    • Wedge the plastic opening tool between the upper and lower halves of the lower case.
    • Lift the end of the opening tool slowly until the case separates.
    • Hearing a small popping or cracking noise during this step is normal
  10. Lenovo ThinkPad Edge E420s Motherboard Replacement: passo 10, imagem 1 %32
    • Lift the upper half of the case up slowly.
    • Be sure not to yank any of the wires connected to the case as this could damage them.
  11. Lenovo ThinkPad Edge E420s Motherboard Replacement: passo 11, imagem 1 %32 Lenovo ThinkPad Edge E420s Motherboard Replacement: passo 11, imagem 2 %32 Lenovo ThinkPad Edge E420s Motherboard Replacement: passo 11, imagem 3 %32
    • Locate and disconnect the 4 ribbon wires from the top case.
    • Locate and disconnect the two additional connecting wires.
    • Some wires may be connected by a clamp. In order to remove the clamp, press upwards on the lever attached to the connector
    • Be careful to not yank on the wires when disconnecting them as they are easily damaged.
  12. Lenovo ThinkPad Edge E420s Motherboard Replacement: passo 12, imagem 1 %32
    • Lift the unattached case away from the device and place it to the side.
    • When reassembling ensure that all parts of the case are properly aligned.
  13. Lenovo ThinkPad Edge E420s Motherboard Replacement, Battery: passo 13, imagem 1 %32 Lenovo ThinkPad Edge E420s Motherboard Replacement, Battery: passo 13, imagem 2 %32
    • Disconnect the cable connecting the battery and the motherboard
  14. Lenovo ThinkPad Edge E420s Motherboard Replacement: passo 14, imagem 1 %32 Lenovo ThinkPad Edge E420s Motherboard Replacement: passo 14, imagem 2 %32
    • Lift the battery out of the case.
    • The battery is secured by grey plastic tubes passing through the case. To place the battery back in, line up the openings on the battery with the tubes.
  15. Lenovo ThinkPad Edge E420s Motherboard Replacement, Optical Drive: passo 15, imagem 1 %32 Lenovo ThinkPad Edge E420s Motherboard Replacement, Optical Drive: passo 15, imagem 2 %32
    • Remove the two M2 x 3mm securing the the optical drive to the device using a Phillips #000 screwdriver.
  16. Lenovo ThinkPad Edge E420s Motherboard Replacement: passo 16, imagem 1 %32
    • Slide the optical drive away from the motherboard in order to remove it.
  17. Lenovo ThinkPad Edge E420s Motherboard Replacement, Glass Screen: passo 17, imagem 1 %32 Lenovo ThinkPad Edge E420s Motherboard Replacement, Glass Screen: passo 17, imagem 2 %32
    • Unscrew the two M2 x 3mm screws near the hinges using a Phillips #00 screwdriver.
  18. Lenovo ThinkPad Edge E420s Motherboard Replacement: passo 18, imagem 1 %32 Lenovo ThinkPad Edge E420s Motherboard Replacement: passo 18, imagem 2 %32 Lenovo ThinkPad Edge E420s Motherboard Replacement: passo 18, imagem 3 %32
    • Slide the black and grey wires out from underneath the plastic tab with the plastic opening tool.
    • Disconnect the black and grey wires connecting the screen and the motherboard.
  19. Lenovo ThinkPad Edge E420s Motherboard Replacement: passo 19, imagem 1 %32
    • Pull out the fabric covered wire connecting the Screen to the motherboard underneath the cooling fan.
    • Make sure to pull parallel to the slot the wire is connected to, otherwise you may damage or completely break it.
  20. Lenovo ThinkPad Edge E420s Motherboard Replacement: passo 20, imagem 1 %32
    • Lift the screen away from the device.
  21. Lenovo ThinkPad Edge E420s Motherboard Replacement, Fan: passo 21, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove the four M2 x 6mm screws connecting the heatsink to the motherboard.
  22. Lenovo ThinkPad Edge E420s Motherboard Replacement: passo 22, imagem 1 %32 Lenovo ThinkPad Edge E420s Motherboard Replacement: passo 22, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove the two M2 x 3mm screws from the fan.
  23. Lenovo ThinkPad Edge E420s Motherboard Replacement: passo 23, imagem 1 %32 Lenovo ThinkPad Edge E420s Motherboard Replacement: passo 23, imagem 2 %32
    • Disconnect the cable connecting the fan to the motherboard, then remove the fan and the attached fan component from the case.
  24. Lenovo ThinkPad Edge E420s Motherboard Replacement, Motherboard: passo 24, imagem 1 %32
    • Use a Phillips #000 screwdriver to remove three M2 x 2mm screws from the sides of the motherboard.
  25. Lenovo ThinkPad Edge E420s Motherboard Replacement: passo 25, imagem 1 %32 Lenovo ThinkPad Edge E420s Motherboard Replacement: passo 25, imagem 2 %32
    • Disconnect the cable connecting the VGA connector to the motherboard. Then disconnect the cable connecting the card reader to the motherboard.
  26. Lenovo ThinkPad Edge E420s Motherboard Replacement: passo 26, imagem 1 %32
    • Lift the motherboard from the case and detach the cable from the back of the motherboard connecting to the DC power jack. Remove the motherboard from the case.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 674
