Ir para o conteúdo principal
Lenovo ThinkPad E570 Wi-Fi Card Replacement
O que você precisa
  1. Lenovo ThinkPad E570 Wi-Fi Card Replacement, Wi-Fi Card: passo 1, imagem 1 %32
    • Turn the laptop over so that the bottom is facing upwards.
  2. Lenovo ThinkPad E570 Wi-Fi Card Replacement: passo 2, imagem 1 %32
    • Unscrew two captive 5 mm screws from the back panel of the laptop using a Phillips #00 screwdriver.
    • Carefully remove the back panel.
  3. Lenovo ThinkPad E570 Wi-Fi Card Replacement: passo 3, imagem 1 %32
    • Carefully remove the black and white coaxial cables that are connected to the chip using an opening tool.
  4. Lenovo ThinkPad E570 Wi-Fi Card Replacement: passo 4, imagem 1 %32
    • Remove the single 4 mm screw from the Wi-Fi card using a Phillips #0 screwdriver.
  5. Lenovo ThinkPad E570 Wi-Fi Card Replacement: passo 5, imagem 1 %32
    • When the screw is removed, the chip will pop up at an angle.
    • Carefully grab the chip and pull outward to remove it from the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 4
Últimos 30 dias: 31
Ao todo: 485
