Ir para o conteúdo principal
Lenovo ThinkPad E570 Fan Replacement
O que você precisa
  1. Lenovo ThinkPad E570 Fan Replacement, CMOS Battery: passo 1, imagem 1 %32 Lenovo ThinkPad E570 Fan Replacement, CMOS Battery: passo 1, imagem 2 %32 Lenovo ThinkPad E570 Fan Replacement, CMOS Battery: passo 1, imagem 3 %32
    • Turn the laptop over so that the bottom is facing upwards, with the battery facing away from you.
    • Loosen two captive 5 mm screws on the back panel of the laptop using a Phillips #0 screwdriver.
    • Slide the panel towards you, then gently lift up to remove.
  2. Lenovo ThinkPad E570 Fan Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad E570 Fan Replacement: passo 2, imagem 2 %32
    • Insert the flat end of the halberd spudger underneath the battery to free the it from the adhesive.
    • Unplug the connecting CMOS wire from the motherboard.
    • When reassembling, apply gentle pressure to the new CMOS battery with the adhesive pad facing down.
  3. Lenovo ThinkPad E570 Fan Replacement, Fan: passo 3, imagem 1 %32 Lenovo ThinkPad E570 Fan Replacement, Fan: passo 3, imagem 2 %32
    • Remove the single 5 mm screw using a Phillips #00 screwdriver.
    • Remove the SSD from the laptop.
  4. Lenovo ThinkPad E570 Fan Replacement: passo 4, imagem 1 %32
    • Using an opening tool, carefully remove the black and white coaxial cables that are connected to the Wi-Fi card.
    • Remove the single 4 mm screw from the Wi-Fi card using a Phillips #0 screwdriver.
    • Carefully grab the card and pull outward to remove it from the laptop.
  5. Lenovo ThinkPad E570 Fan Replacement: passo 5, imagem 1 %32 Lenovo ThinkPad E570 Fan Replacement: passo 5, imagem 2 %32
    • Using both hands, push out the two buttons beneath the outer edges of the battery compartment.
    • Pull out the battery from the laptop.
  6. Lenovo ThinkPad E570 Fan Replacement: passo 6, imagem 1 %32 Lenovo ThinkPad E570 Fan Replacement: passo 6, imagem 2 %32
    • Remove the three screws in storage area. Then, remove warranty strip.
  7. Lenovo ThinkPad E570 Fan Replacement: passo 7, imagem 1 %32 Lenovo ThinkPad E570 Fan Replacement: passo 7, imagem 2 %32
    • Remove the three 4 keyboard screws in the middle of the casing and all the outer casing screws.
  8. Lenovo ThinkPad E570 Fan Replacement: passo 8, imagem 1 %32
    • After removing the screws slide the disc drive out.
    • Use size 0 bit to remove three 3 screws on frame under disc drives and Flip over laptop to open it.
  9. Lenovo ThinkPad E570 Fan Replacement: passo 10, imagem 1 %32 Lenovo ThinkPad E570 Fan Replacement: passo 10, imagem 2 %32 Lenovo ThinkPad E570 Fan Replacement: passo 10, imagem 3 %32
    • Gently press against the keyboard to slide it up and out. Then gently flip the keyboard over.
  10. Lenovo ThinkPad E570 Fan Replacement: passo 11, imagem 1 %32 Lenovo ThinkPad E570 Fan Replacement: passo 11, imagem 2 %32 Lenovo ThinkPad E570 Fan Replacement: passo 11, imagem 3 %32
    • Disconnect the keyboard cables.
  11. Lenovo ThinkPad E570 Fan Replacement: passo 12, imagem 1 %32
    • Disconnect fingerprint sensor.
  12. Lenovo ThinkPad E570 Fan Replacement: passo 13, imagem 1 %32
    • Disconnect mouse cable.
  13. Lenovo ThinkPad E570 Fan Replacement: passo 14, imagem 1 %32
    • Disconnect speaker cable.
  14. Lenovo ThinkPad E570 Fan Replacement: passo 15, imagem 1 %32
    • Disconnect power button cable.
  15. Lenovo ThinkPad E570 Fan Replacement: passo 16, imagem 1 %32 Lenovo ThinkPad E570 Fan Replacement: passo 16, imagem 2 %32
    • Remove front casing screws.
  16. Lenovo ThinkPad E570 Fan Replacement: passo 17, imagem 1 %32 Lenovo ThinkPad E570 Fan Replacement: passo 17, imagem 2 %32
    • Wedge the casing apart.
  17. Lenovo ThinkPad E570 Fan Replacement: passo 18, imagem 1 %32
    • Remove the motherboard screws.
  18. Lenovo ThinkPad E570 Fan Replacement: passo 19, imagem 1 %32
    • Remove the screen cable by pulling the tab back.
  19. Lenovo ThinkPad E570 Fan Replacement: passo 20, imagem 1 %32
    • The mother boards should be able to be removed at this point and flipped over to get access to the CPU chip and the fan.
  20. Lenovo ThinkPad E570 Fan Replacement: passo 21, imagem 1 %32 Lenovo ThinkPad E570 Fan Replacement: passo 21, imagem 2 %32
    • Disconnect Fan connector and remove the screws from the heatsink and replace the fan. (Fan part number)
Conclusão
KyleH
Membro desde: 07/13/23
427 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 1-2, Harley Summer 2023 Membro de IUPUI, Team 1-2, Harley Summer 2023
IUPUI-HARLEY-SU23S1G2
3 Membros
Autoria de 3 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 40
Ao todo: 544
