Introdução
In this guide, moving the camera is the main focus. Digital cameras themselves are very complex, however, this guide will show you just how easy it is to replace one.
O que você precisa
Gently insert a spudger into one of the bottom corners between the screen and body case.
Slide the spudger along the inside of the crack in order to pry the case open.
Ferramenta utilizada nesse passo:Plastic Cards$2.99
Gently lift the flaps on the four ZIF connectors to disconnect the cables.
Use the plastic card to gently pry the battery from the device.
Uma outra pessoa concluiu este guia.
