Ir para o conteúdo principal
Lenovo Tab 4 8 MicroSD Card Reader Replacement
O que você precisa
  1. Lenovo Tab 4 8 MicroSD Card Reader Replacement, Battery: passo 1, imagem 1 %32 Lenovo Tab 4 8 MicroSD Card Reader Replacement, Battery: passo 1, imagem 2 %32 Lenovo Tab 4 8 MicroSD Card Reader Replacement, Battery: passo 1, imagem 3 %32
    • Start at the microSD slot.
    • Use the opening pick to slide underneath the back cover of the tablet.
    • Slide the opening pick around the tablet until the back cover is off.
  2. Lenovo Tab 4 8 MicroSD Card Reader Replacement: passo 2, imagem 1 %32 Lenovo Tab 4 8 MicroSD Card Reader Replacement: passo 2, imagem 2 %32 Lenovo Tab 4 8 MicroSD Card Reader Replacement: passo 2, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the 8 screws with a Phillips #000 screwdriver [bit].
    • There is a screw under the blue "s" sticker.
    • Remove tape holding plate down.
    • Use precision tweezers or your fingers to remove plate.
  3. Lenovo Tab 4 8 MicroSD Card Reader Replacement: passo 3, imagem 1 %32 Lenovo Tab 4 8 MicroSD Card Reader Replacement: passo 3, imagem 2 %32
    • Remove yellow tape.
    • Use a spudger or plastic opening tool to remove the battery's ribbon cable from the motherboard.
  4. Lenovo Tab 4 8 MicroSD Card Reader Replacement: passo 4, imagem 1 %32 Lenovo Tab 4 8 MicroSD Card Reader Replacement: passo 4, imagem 2 %32 Lenovo Tab 4 8 MicroSD Card Reader Replacement: passo 4, imagem 3 %32
    • Gently pull on the two stretch release adhesive strips. Do not pull up, pull away from battery.
    • Once the tabs are off, lift the battery up from the frame.
    • Do not bend or puncture the battery.
  5. Lenovo Tab 4 8 MicroSD Card Reader Replacement, MicroSD Card Reader: passo 5, imagem 1 %32 Lenovo Tab 4 8 MicroSD Card Reader Replacement, MicroSD Card Reader: passo 5, imagem 2 %32
    Comprar
    • There is a yellow tape holding the microSD card reader connector. Use tweezers to hold down the tape.
    • Gently lift the tab on the microSD card reader's ZIF connector, and gently pull the ribbon cable free.
  6. Lenovo Tab 4 8 MicroSD Card Reader Replacement: passo 6, imagem 1 %32 Lenovo Tab 4 8 MicroSD Card Reader Replacement: passo 6, imagem 2 %32
    • Lift the microSD card reader with tweezers or your fingers.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 14
Duração total: 809
