Ir para o conteúdo principal
Lenovo Tab 2 A8 Volume & Power Button Sensor Replacement
O que você precisa
  1. Lenovo Tab 2 A8 Volume & Power Button Sensor Replacement, Removing the Back Panel: passo 1, imagem 1 %32 Lenovo Tab 2 A8 Volume & Power Button Sensor Replacement, Removing the Back Panel: passo 1, imagem 2 %32 Lenovo Tab 2 A8 Volume & Power Button Sensor Replacement, Removing the Back Panel: passo 1, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Place the tablet face down on a soft, stable surface that will protect the screen.
    • Next, Scrape off the seal over the screw in the back of the tablet with a Metal Spudger.
    • Use the Phillips #000 Screwdriver to remove the M1.4 × 2.5 screw.
    • If the seal covering the screw has already been removed, please proceed to the next step in the process.
    • As the screw is small, you may wish to extract it using a pair of tweezers.
  2. Lenovo Tab 2 A8 Volume & Power Button Sensor Replacement: passo 2, imagem 1 %32 Lenovo Tab 2 A8 Volume & Power Button Sensor Replacement: passo 2, imagem 2 %32 Lenovo Tab 2 A8 Volume & Power Button Sensor Replacement: passo 2, imagem 3 %32
    • Starting on the side, work your way around the the tablet to pop off the back cover. You will want to utilize a metal Spudger for this.
    • Some force may be required initially to pry the back cover off.
    • Note that the button tabs for this device are loose inside the case and will fall out when opening.
  3. Lenovo Tab 2 A8 Volume & Power Button Sensor Replacement, Volume & Power Button Sensor: passo 3, imagem 1 %32 Lenovo Tab 2 A8 Volume & Power Button Sensor Replacement, Volume & Power Button Sensor: passo 3, imagem 2 %32
    Comprar
    • Use tweezers to gently lift the button panel away from the device. Be aware that pulling on the ribbon with too much force could tear the ribbon cable.
    • Carefully desolder the button strip contact point.
Conclusão
3 outras pessoas executaram este guia.
Taylor Smith
Membro desde: 01/26/17
382 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 2-4, Baechle Spring 2017 Membro de IUPUI, Team 2-4, Baechle Spring 2017
IUPUI-BAECHLE-S17S2G4
Membros da 4
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 7
Últimos 30 dias: 36
Duração total: 2,769
