Introdução
This guide illustrates the procedure to remove the rear-facing camera of your device.
O que você precisa
Ferramenta utilizada nesse passo:Tweezers$4.99
Place the tablet face down on a soft, stable surface that will protect the screen.
Next, Scrape off the seal over the screw in the back of the tablet with a Metal Spudger.
Use the Phillips #000 Screwdriver to remove the M1.4 × 2.5 screw.
Using a spudger, pry upward on the camera connector to free it from the motherboard.
4 outras pessoas executaram este guia.
