Ir para o conteúdo principal
Lenovo Tab 2 A10-70 Rear Facing Camera Replacement
O que você precisa
  1. Lenovo Tab 2 A10-70 Rear Facing Camera  Replacement, Rear Facing Camera: passo 1, imagem 1 %32
    • Before removing the camera, make sure the device is powered off
    • Use a plastic opening tool to pry open the back cover of the tablet..
  2. Lenovo Tab 2 A10-70 Rear Facing Camera  Replacement: passo 2, imagem 1 %32
    • Locate the cable that is connecting the camera to the tablet
  3. Lenovo Tab 2 A10-70 Rear Facing Camera  Replacement: passo 3, imagem 1 %32
    • Disconnect the cable that is connecting the camera to the tablet
  4. Lenovo Tab 2 A10-70 Rear Facing Camera  Replacement: passo 4, imagem 1 %32 Lenovo Tab 2 A10-70 Rear Facing Camera  Replacement: passo 4, imagem 2 %32
    • Simply remove the camera from the tablet by lifting it up
    • Repeat Steps in reverse order with a new camera for reassembly
Conclusão
Equipe
USF Tampa, Team 12-6, Eyestone Spring 2016 Membro de USF Tampa, Team 12-6, Eyestone Spring 2016
USFT-EYESTONE-S16S12G6
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 12
Duração total: 887
