Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
Use this guide to remove the USB 2.0 Power Assembly for replacement.
  1. Flip the unit over so the bottom is facing you. Remove the two black 7.6mm Phillips #0 screws from the bottom cover.
    • Flip the unit over so the bottom is facing you.
    • Remove the two black 7.6mm Phillips #0 screws from the bottom cover.
  2. Use the iFixit Opening Tool to gently pry the unit apart to gain access to the interior. If the top seems stuck, run the iFixit Opening Tool along the edge while simultaneously pulling up on the top with your fingers. Continue to apply pressure until it opens completely.
    • Use the iFixit Opening Tool to gently pry the unit apart to gain access to the interior.
    • If the top seems stuck, run the iFixit Opening Tool along the edge while simultaneously pulling up on the top with your fingers. Continue to apply pressure until it opens completely.
  3. Open the device tray by inserting  a paper clip into the eject hole. Open the device tray by inserting  a paper clip into the eject hole.
    • Open the device tray by inserting a paper clip into the eject hole.
  4. Remove the  two silver 3mm Phillips #0 screws from the mini USB circuit board. Remove the  two silver 3mm Phillips #0 screws from the mini USB circuit board.
    • Remove the two silver 3mm Phillips #0 screws from the mini USB circuit board.
  5. Kits para o Nintendo Switch
    Um reparo rápido para reiniciar o jogo
    Confira kits para o Nintendo Switch
  6. Turn the unit over and remove the two silver 3mm Phillips #0 screws from the aluminum cover. Turn the unit over and remove the two silver 3mm Phillips #0 screws from the aluminum cover.
    • Turn the unit over and remove the two silver 3mm Phillips #0 screws from the aluminum cover.
  7. Lift up and remove the silver cover to expose the internal components.
    • Lift up and remove the silver cover to expose the internal components.
    • If the cover seems stuck gently pull up on one edge. The cover should remove completely after one side is free.
  8. Remove the two ribbon cables using any pair of ESD(electrostatic discharge) safe tweezers. The ribbons wires are fragile but still require a firm force to remove.
    • Remove the two ribbon cables using any pair of ESD(electrostatic discharge) safe tweezers.
    • The ribbons wires are fragile but still require a firm force to remove.
  9. Use the iFixit Opening Tool to flip up the grey locking flap on the ZIF (zero insertion force) connector to allow removal of the ribbon cable. Remove the large ribbon wire using any pair of ESD safe tweezers.
    • Use the iFixit Opening Tool to flip up the grey locking flap on the ZIF (zero insertion force) connector to allow removal of the ribbon cable.
    • Remove the large ribbon wire using any pair of ESD safe tweezers.
  10. Remove  the single 3mm Phillips #0 screw to loosen the large circuit board. Remove  the single 3mm Phillips #0 screw to loosen the large circuit board.
    • Remove the single 3mm Phillips #0 screw to loosen the large circuit board.
  11. Pull up on the large circuit board and slide it through the opening with the ribbon cable attached to it.
    • Pull up on the large circuit board and slide it through the opening with the ribbon cable attached to it.
    • The large circuit board should end up on the other side of the device next to the Mini USB circuit board.
  12. Remove the power assembly by peeling it away from the unit. The two circuit boards, which make up the power assembly, are connected together with a white ribbon cable.
    • Remove the power assembly by peeling it away from the unit.
    • The two circuit boards, which make up the power assembly, are connected together with a white ribbon cable.
    • Take your time when removing the power assembly, as it requires a firm amount of force to peel away and remove.
Conclusão
Matthew Green
Membro desde: 05/07/2018
337 Reputação
2 Guias de autoria
Equipe
IUPUI, Team S2-G1, Harley Summer 2018 Membro de IUPUI, Team S2-G1, Harley Summer 2018
IUPUI-HARLEY-SU18S2G1
3 Membros
2 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 12
Duração total: 387
